How to configure IPAD to connect Wireless (WPA2)
vinodjad1234 Mon, 08/23/2010 - 22:09
As I understood , you need configuration on controller side ...  if that is the case... please follow below procedure ..
once you login to controller through GUI ... you need to select " Wireless " option
1) select wlan which you want to configure with WPA2 ...
2) you will get page with all details about corrousponding WLAN
3) select " Security " option in wlan option
4) once you click on security option , you will get option with WPA+ WPA2
5) select that option with what type of encryption you required ...
I believe you need wpa2 with personal edition. if so ... please select PSK with TKIP option .
once you do that , it will be activated from controller side for the respective Wlan ...
About IPAD ... you need to select wpa+wpa2 with psk and TKIP .... I do not have clear idea about IPAD ...
vinodjad1234 Tue, 08/24/2010 - 22:43
login to controller through console or telnet and give below commands
1) show client details < client MAC address >
2) debug lwapp client ?
let me know whether your requirement is fulfilled?
thanks,
vinod
George Stefanick Wed, 08/25/2010 - 16:15
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Best Publication, October 2015
If you want to do advance security with the iPad you will be required to download the apple utility to open these options.
http://support.apple.com/kb/dl926
Is this what you are looking for?
