VPN Logs
Answered Question
Aug 23rd, 2010
I wanted to know is there a way through ASDM to look at if a user was connected to the network over the weekend and if so for how long.
Thanks in advance and have a great day.
Correct Answer by uwkleinh about 6 years 7 months ago
You can enable logging in ASDM under 'Monitoring' with a severity of 4 or higher and you should see some syslog messages:
4|Aug 23 2010|14:28:33|113019|||||Group = IPSEC-RA, Username = ipsec-ra, IP = x.x.x.x, Session disconnected. Session Type: IPsec, Duration: 0h:01m:46s, Bytes xmt: 540, Bytes rcv: 576, Reason: User Requested
On the CLI:
'show log | i ASA-4-113019'
%ASA-4-113019: Group = IPSEC-RA, Username = ipsec-ra, IP = x.x.x.x, Session disconnected. Session Type: IPsec, Duration: 0h:01m:46s, Bytes xmt: 540, Bytes rcv: 576, Reason: User Requested
CLI command would be:
'logging enable'
'logging asdm informational' (for ASDM)
'logging buffered informational' (for CLI buffer logging)
Overall Rating: 5 (1 ratings)
skalaven Mon, 08/23/2010 - 14:44
  • Cisco Employee,
You could look at the buffer config you have and see if you have logs stored, internal buffer can only store upto 1MB but by default it is 4KB unless you change it. Depending on the chattiness of your device i would say the old logs are probably gone. So to answer your question it is not possible to look at this info. if you have a external syslog server like MARS then you could probably get this info.
hope this helps.
--Sunil
Correct Answer
uwkleinh Mon, 08/23/2010 - 14:48
On the CLI:
'logging enable'
