How to setup IMAP for CUCMBE to check Voicemail Messages
Answered Question
Aug 23rd, 2010
Hi all, I have a CUCMBE installation and have a ton of Voice Messages in our "UndeliverableMessagesMailbox". When I try to check the mailbox by dialing the extension, the pin that I have reset a number of times, will not work and gives me an "invalid entry".
Moving forward, the amount that I need to check is huge and I thought possible checking the VM's via IMAP is the way to go.
Can anyone give me any steps in setting IMAP up? It does not need to be neat I just need to access these Voice Messages.
Here is my info:
Cisco Unified CM Administration System version: 6.1.3.2000-1
Cisco Unity Connection version: 2.1.3ES23.1000-23
Thanks for the help,
Dan
Correct Answer by David Hailey about 6 years 9 months ago
IMAP access if first enabled via the Class of Service assigned to a subscriber - so you must take care of that first.  Then, take a look here:
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/7x/user_mac/guide/7xcucmac050.html#IMAP_Client_Access_to_Voice_Messages
Hailey
Please rate helpful posts!
Overall Rating: 5 (2 ratings)
philip.e.denton Tue, 08/24/2010 - 05:06
  • Silver, 250 points or more
David is correct (rated) but IMAP integration can be tricky so reply if you get stuck.
dan hale Tue, 08/24/2010 - 08:39
Thanks guys.....David was correct I never would have thought to look in COS. Enabled
IMAP in Class of Service and I'm able to pulls VM's!
Dan!
David Hailey Tue, 08/24/2010 - 08:42
  • Purple, 4500 points or more
Good deal. It's actually not too tricky IMO. However, many people get confused when looking at the System and Administration guides because a lot of information regarding SMTP and IMAP are lumped together in the same section of documentation and they should likely be handled separately from a documentation perspective. Glad to hear all is well.
Hailey
Related Content
