AIP-SSM on contexts or transparent
Answered Question
Aug 23rd, 2010
I would like to know if its possible to have an AIP-SSM module on a ASA configured in trasparent mode and if its possible to have it in multiple contexts. Two different scenarios. The client wants to know that and I would like to see it on a Cisco document if possible. I think both scenarios are possible but I haven't found any document.
Paul
Correct Answer by skalaven about 6 years 6 months ago
Hi Paul,
Here is the link which explains how you can configure multiple virtual sensors and as you can see it is supported on both routed and transaprent mode.
http://www.cisco.com/en/US/docs/security/asa/asa82/configuration/guide/ips.html#wp1087111
Hope this helps.
--Sunil
Overall Rating: 5 (1 ratings)
Jia Liu Mon, 08/23/2010 - 15:25
Yes, you can have an AIP-SSM module on an ASA configured in transparent mode or in multiple contexts.  I could not find a document that mentions trasnparent mode but you'll see reference to multiple context in the documents below:
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ssm.html#wp1097278
http://www.cisco.com/en/US/docs/security/asa/asa80/configuration/guide/ssm.html#wp1091984
Related Content
