Unity 4.04 VM to Unity 7.x UM -best approach
Aug 23rd, 2010
what is the best approach to take to upgrading this customer from unity 4.x voicemail only to unity 7 unified messaging on a new server?
David Hailey Mon, 08/23/2010 - 15:26
From a migration perspective, 4.0(4) is the limiting factor.  So, if you are building a new server and expect to "migrate" data then here's what you have:
1) Upgrade 4.0(4) to 4.0(5)
2) Once you are on 4.0(5), you can use the COBRAS migration tools to export the Unity data that you want to migrate
3) Build the new Unity 7 server (fully, integrated with AD, Exchange, etc).
4) Depending on the version of Exchange (i.e., if you are using 2007 or higher) then you will need to create the Subscribers on the new system in advance (i.e., import only with this version of Exchange)
5) Use COBRAS Data Viewer to map old Unity alias to new alias (if needed)
6) Build out Unity components that cannot be migrated (see COBRAS help file)
7) Use COBRAS import to import the Unity 4x data and choose to overwrite the existing Subscriber data (i.e., the users are already created if on Exchange 2007)
Note, if using Exchange 2003 then COBRAS can create all the objects as usual.
Hailey
Please rate helpful posts!
kiru Tue, 08/24/2010 - 08:03
cant i use DiRT and migrate subsriber data tool?
David Hailey Tue, 08/24/2010 - 08:07
If you are using a new server, DiRT would be quite a bit of extra work.  You would have to build the server to the exact same version of Unity 4.0(4) including ES releases as the old server.  Then you would need to do a DiRT backup and restore to the new server.  Then you would end up having to do an in-place upgrade/rebuild of the new server to get to 7x.  So, I wouldn't consider that a very good option.  Migrate Subscriber Data tool would never enter the picture as you'd be restoring the old system to a new server...that tool is for the systems within the same AD domain.
Hailey
kiru Tue, 08/24/2010 - 08:13
they are on exchange 2007 so what do you mean by this?
David Hailey Tue, 08/24/2010 - 08:19
With Exchange 2007, Unity cannot create Subscribers. It can only import. This is a known limitation and is outlined in the design guide for Unity. So, when you build the Unity 7x system you will need to ensure all of the Unity subscribers have an AD account and Exchange 2007 mailbox created on the corporate AD. From there, you would import them into the Unity 7x server as new subscribers.
You then use COBRAS Data Viewer to map old Unity aliases to new Unity 7x aliases.
When you import data from COBRAS, aliases will then match and you can overwrite the subscriber data to import old settings (passwords, greetings, etc).
Read up on COBRAS via the Help File on www.ciscounitytools.com.
Hailey
reza aminzaboli Tue, 08/24/2010 - 18:29
Hi David,
We have a similar scenario with 4.0.3 VM to be upgraded to 7 full UM on a new HW.
with Exchange 2003..please will you elaborate on the steps?
many thanks
R
David Hailey Tue, 08/24/2010 - 20:29
Steps are very similar, see below:
1) Upgrade 4.0(3) to 4.0(5)
3) Build the new Unity 7 server (fully, integrated with AD, Exchange, etc).  Grant Unity the right to create AD users, exchange mailboxes, distribution lists, and etc (since you have Exchange 2003).
4) Build out Unity components that cannot be migrated (see COBRAS help file)
5)  Use COBRAS import to import the Unity 4x data and with the proper permissions, COBRAS/Unity can create objects with the proper permissions (see 3 above).
Hailey
reza aminzaboli Wed, 08/25/2010 - 05:29
thank you for the reply.
is there any video training/presentation going through the steps?
many thanks
David Hailey Wed, 08/25/2010 - 06:56
For the actual Unity work such as upgrading to 4.0(5) and the install of the new system, no videos there - the best training is years of on the job experience with not only Unity but also AD/Exchange.
For COBRAS, yes there are some videos and other info specific to it's usage:
I have a tech presentation that focuses on migrating to Unity Connection but you can still review it to get a feel for what COBRAS is like (export/import is similar in either case):
http://www.netcraftsmen.net/user-group/c-mug-archive/824-cisco-unity-con...
Make sure you read the COBRAS Help File. A lot of people skip this for whatever reason and then they pay for it. Read it, know it - BEFORE moving forward:
http://www.ciscounitytools.com/Applications/General/COBRAS/Help/COBRAS.htm
Training videos for COBRAS here:
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Hailey
Please rate helpful posts!!!
reza aminzaboli Thu, 08/26/2010 - 17:38
Hi David
I checked your presentation and it was excellent. appreiated!!!
I belive for now the best thing to do isto put everything on VMWARE. Can I run Unit 7 on a LAB vmware ? is there any consideration?
R
David Hailey Fri, 08/27/2010 - 01:01
You can run Unity for lab purposes on VMWare.  I currently have both version 5 and 7 in my lab and have deployed in various scenarios:
1) Unity/Exchange/AD on same box (performance was a bit slow)
2) Unity w/Exchange 2003 and AD off-box
3) Unity w/Exchange 2007 and AD off-box
You'll just need to use a commercial copy of the Windows OS for your install and you should be good to go.
Hailey
reza aminzaboli Fri, 08/27/2010 - 02:12
Hi David,
So if i want to use ESX or VMWare client there is no consideration like RAM, Harddarive etc? just a valid 2003 MS server?
Reza
David Hailey Fri, 08/27/2010 - 07:09
Well, I always try to stick a standard build for my lab machines.
Technically, Unity 7 is supported for production use in VMWare so if you
really want to know actual production specifications you can obtain that
documentation easily from cisco.com. BUT, for lab purposes this is what I
do:
2 GB RAM (you can do less but Unity will perform poorly - and I mean poorly)
72 GB HD (do not allocate all of the space at once - let it grow as it
needs)
I always partition a C and D drive at a minimum. I keep the OS on a C
partition of 12-16 GB (your choice) and partition the rest for Unity as D:
That's it. I use VMWare Server 2.x in my lab.
Hailey
On Fri, Aug 27, 2010 at 5:12 AM, reza.aminzaboli <
David Hailey Fri, 08/27/2010 - 11:31
10 subscribers, 2 ports.
On Fri, Aug 27, 2010 at 2:28 PM, reza.aminzaboli <
