Desktop Agent Updates
Aug 23rd, 2010
I'm a newbie to Contact Call center. I running version 7. When I download the client from the server it requests updates to the client (Desktop Agent). Where is the client (Desktop Agent) getting the updates from?   Is it coming from the server or cisco?  How can I verify it?
Overall Rating: 5 (3 ratings)
Tanner Ezell Mon, 08/23/2010 - 17:29
  • Silver, 250 points or more
It's stored locally on the UCCX server.
C:\Program Files\wfavvid\tomcat_appadmin\TUP\CAD i believe (should be
close to that)..
On Mon, Aug 23, 2010 at 8:24 PM, dcnetworkengineer
Jay Cambell Mon, 08/23/2010 - 17:33
Does the server automatically look for updates then download it to this location?
Aaron Harrison Tue, 08/24/2010 - 00:24
  • Community Spotlight Award,
    Member's Choice, May 2015
No - the updates are made available only when you apply upgrades or SRs. So base 7.0.1 release would just have the initial install, but if you install a Service Release you will probably find a 'CAD Clients Service Release.msi' file at the location Tanner mentioned.
You don't always get a new CAD SR when you install a new UCCX SR, but you usually do. Check if the CAD versions have changed on the UCCX Compatibility sheet when planning any upgrades if you need to know (i.e. if you push out the MSIs via a desktop management system...) http://www.cisco.com/en/US/docs/voice_ip_comm/cust_contact/contact_center/crs/express_compatibility/matrix/crscomtx.pdf
Aaron
Please rate helpful posts...
joesnyde Tue, 08/24/2010 - 04:28
  • Cisco Employee,
Hi Jay,
A little more to add, the file update.exe this runs from the Agent PC where CAD is installed (C:\Program Files\Common Files\CAD\bin) and runs a check against the server version, then returns with an update if one is available.
Joe
