From Cisco 873 to ASA 5505 (Firewall)
Answered Question
Aug 23rd, 2010
We have an old Cisco 873 for ADSL but we need the firewall configuration of this to be put into an ASA 5505 7.2(4). Can someone please check the configuration below if correct? If there is needed to change please help.
Cisco 873:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Current configuration : 5442 bytes
version 12.4
no service pad
service password-encryption
hostname ABXC
boot-start-marker
boot-end-marker
logging count
logging userinfo
logging buffered 51200 warnings
no logging console
enable secret 5 XXXXXXX.
no aaa new-model
resource policy
clock timezone EST 10
ip subnet-zero
ip cef
ip inspect name firewall cuseeme
ip inspect name firewall ftp
ip inspect name firewall h323
ip inspect name firewall rcmd
ip inspect name firewall realaudio
ip inspect name firewall sqlnet
ip inspect name firewall streamworks
ip inspect name firewall tcp
ip inspect name firewall tftp
ip inspect name firewall udp
ip inspect name firewall vdolive
ip inspect name firewall smtp
ip domain name nph.com.au
ip name-server 202.xx.xx.68
crypto pki trustpoint TP-self-signed-1043400621
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1043400621
revocation-check none
rsakeypair TP-self-signed-1043400621
crypto pki certificate chain TP-self-signed-1043400621
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 31303433 34303036 3231301E 170D3032 30333031 30303036
  33385A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 30343334
  30303632 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100B74E BE67168A 4EC408C6 F9251228 EB9FE03D 47711E81 B378A366 86D025BE
  3BA155D0 00F3B41B 0C46BC21 8720BBEA 208F7882 201B5699 38472B7C 798A24BF
  ED9CBBE5 7AD31DDA 36B9E538 8F6C9BA1 F5B6B507 AC47234E 8362A372 94F1110A
  D58428F7 54BF6CAA 49591A32 488E2F51 351D458D 4561DE1A 6B6C056E 58994880
  F7F50203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 1441C472 992A94B4 3A4A9ECF 1A386453 C00BD4F4
  41301D06 03551D0E 04160414 41C47299 2A94B43A 4A9ECF1A 386453C0 0BD4F441
  300D0609 2A864886 F70D0101 04050003 81810094 B3197EB1 054E82DD 4F8F033F
  33BD0B01 511D9449 109BA2E9 4B013D9A 22D7AF49 2A402F69 D862FD37 28687895
  343B1FB3 B161AB63 3836C168 25275896 11E2B828 585B7187 A53AE424 CA12F341
  F58B90DB 53F2C018 5480C7D8 AD3E41AB C9C5D5CC 1F700C17 ED7B097B 85512E43
  D9878792 A66ABF71 FE6C95F1 6F1C5AE1 F433EE
  quit
username root password 7 xxxxxxxxxxxxxxxxx
username admin password 7 yyyyyyyyyyyyyyyy
crypto isakmp policy 10
encr 3des
hash md5
authentication pre-share
group 2
crypto isakmp policy 18
encr 3des
group 2
crypto isakmp policy 20
hash md5
group 2
crypto isakmp client configuration group clients
key abc$abc$
dns 10.0.0.7
wins 10.0.0.7
domain ABXC.com.au
pool clients
acl 199
crypto ipsec transform-set strong1 esp-3des esp-md5-hmac
crypto dynamic-map dynmap 10
set transform-set strong1
crypto map axis isakmp authorization list groupauthor
crypto map axis client configuration address respond
crypto map axis 20 ipsec-isakmp dynamic dynmap
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
no snmp trap link-status
pvc 1/34
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.254 255.0.0.0
ip nat inside
ip virtual-reassembly
interface Dialer1
description Internet Network
ip address negotiated
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer idle-timeout 0
dialer persistent
no cdp enable
ppp authentication chap callin
ppp chap hostname 000000000000000000
ppp chap password 7 11111111111111111
ip local pool clients 192.168.10.1 192.168.10.254
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
no ip http server
no ip http secure-server
ip nat inside source static tcp 10.0.0.241 3391 interface Dialer1 3391
ip nat inside source static tcp 10.0.0.241 25 interface Dialer1 25
ip nat inside source static tcp 10.0.0.7 80 interface Dialer1 80
ip nat inside source static tcp 10.0.0.241 443 interface Dialer1 443
ip nat inside source static tcp 10.0.0.240 1723 interface Dialer1 1723
ip nat inside source static tcp 10.0.0.243 5190 interface Dialer1 5190
ip nat inside source static tcp 10.0.0.7 110 interface Dialer1 110
ip nat inside source static tcp 10.0.0.7 3389 interface Dialer1 3390
ip nat inside source static tcp 10.0.0.8 3389 interface Dialer1 3389
ip nat inside source route-map dialer-route-map interface Dialer1 overload
logging origin-id hostname
logging 10.0.0.7
access-list 108 deny   ip 10.0.0.0 0.255.255.255 192.168.10.0 0.0.0.255
access-list 108 permit ip 10.0.0.0 0.255.255.255 any
access-list 199 permit ip 10.0.0.0 0.255.255.255 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
snmp-server community NPH RO
no cdp run
route-map dialer-route-map permit 1
match ip address 108
control-plane
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
ntp server 202.xx.xx.2
end
Cisco ASA 5505:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
ASA Version 7.2(4)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd xxxx encrypted
names
name 10.0.0.8 psvr03
name 10.0.0.7 psvr02
name 10.0.0.240 vsvr02
name 10.0.0.241 vsvr01
name 10.0.0.243 vwks02
interface Vlan1
nameif inside
security-level 100
ip address 10.0.0.242 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address 125.xx.xx.238 255.0.0.0
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
ftp mode passive
dns server-group DefaultDNS
access-list outside_access_in extended permit tcp any interface outside eq 3391
access-list outside_access_in extended permit tcp any interface outside eq smtp
access-list outside_access_in extended permit tcp any interface outside eq https
access-list outside_access_in extended permit tcp any interface outside eq www
access-list outside_access_in extended permit tcp any interface outside eq pptp
access-list outside_access_in extended permit tcp any interface outside eq pop3
access-list outside_access_in extended permit tcp any interface outside eq 3389
access-list inbound extended permit tcp any host 125.xx.xx.238 eq 3391
access-list inbound extended permit tcp any host 125.xx.xx.238 eq smtp
access-list inbound extended permit tcp any host 125.xx.xx.238 eq http
access-list inbound extended permit tcp any host 125.xx.xx.238 eq https
access-list inbound extended permit tcp any host 125.xx.xx.238 eq pptp
access-list inbound extended permit tcp any host 125.xx.xx.238 eq pop3
access-list inbound extended permit tcp any host 125.xx.xx.238 eq 3389
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface 3391 vsvr01 3391 netmask 255.255.255.255
static (inside,outside) tcp interface smtp vsvr01 smtp netmask 255.255.255.255
static (inside,outside) tcp interface https vsvr01 https netmask 255.255.255.255
static (inside,outside) tcp interface www psvr02 www netmask 255.255.255.255
static (inside,outside) tcp interface pptp vsvr02 pptp netmask 255.255.255.255
static (inside,outside) tcp interface pop3 psvr02 pop3 netmask 255.255.255.255
static (inside,outside) tcp interface 3389 psvr02 3389 netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 125.xx.xx.237 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
http server enable
http Axis 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd auto_config outside
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:
: end
asdm location 10.0.0.0 255.0.0.0 inside
Thanks and Regards
Michael
Correct Answer by Nagaraja Thanthry about 6 years 7 months ago
Everything else looks good except that the access-list is not applied to any
interface. Also, the policy NAT is missing.
access-group outside_access_in in interface outside
access-list nonat permit ip 10.0.0.0 255.0.0.0 192.168.10.0 255.255.255.0
nat (inside) 0 access-list nonat
Other than above three lines, everything else looks good.
Hope this helps.
NT
Overall Rating: 5 (1 ratings)
Correct Answer
Nagaraja Thanthry Mon, 08/23/2010 - 19:32
  • Cisco Employee,
Hope this helps.
NT
jaidan2003 Mon, 08/23/2010 - 22:36
Hi NT,
Thanks for a quick reply.
I have added the 3 lines you have told me. But I when I go to test still it would not let me get-in from outside to inside. I test the Packet Tracker in ASDM from outside to inside. It show and cut-off at "access list" look-up (implicit rule) which is blank.
Any idea why is this so?
Michael
Nagaraja Thanthry Tue, 08/24/2010 - 08:08
  • Cisco Employee,
Can you please post your latest configuration again (with the changes you
have made)?
NT
jaidan2003 Tue, 08/24/2010 - 13:55
Hi NT,
Sorry I have found the typo error I made and do the changes correctly. It is all working now.
Thanks for a big help
Michael
