TTL??
Answered Question
Aug 23rd, 2010
I want to know what kind of problem in TTL???
please share with me...
Correct Answer by Peter Paluch about 6 years 10 months ago
Abhinay,
Can you be more specific? There are no problems with TTL per se The TTL is simply a number that limits the maximum number of hops a packet can travel, and, being a 1B quantity, its maximum value is 255 which is the maximum limit on the diameter of any IP network. The TTL prevents a packet from circling in a routing loop endlessly which is a good thing.
Have you heard of any problems with TTL in a particular application?
Best regards,
Peter
Overall Rating: 5 (1 ratings)
Correct Answer
Peter Paluch Tue, 08/24/2010 - 00:36
  • Cisco Employee,
Abhinay,
Best regards,
Peter
