ACS Express Tacacs+ authentication issues
Aug 24th, 2010
hi All,
I am trying to do a simple switch TACACS+ authentication via the ACS Express.
ACS Express - 5.0
IP address (
Core Switch - Catalyst 4948
vlan 1 (
vlan 10 (
Access Switch - Catalyst 3560
vlan 1 (
Problem statement:
On ACS Express:
-core switch device is being created using the ip
-access switch device is being creted using ip
Unfortunately i am unable to authenticate. It shows authentication failed when i tried to login to both core & access switches.
-Tried to change the core switch device ip to, it seems to work - when i telnet to both &
- ACS Express seems to ONLY understands device that belongs to its own subnet i.e /24 network.
- Ip routing has been enabled on core switch and both 192 & 172 network are pingable
Below is the TACACS config on both core & access switch
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication enable default group tacacs+ none
aaa accounting exec default stop-only group tacacs+
aaa accounting commands 15 default stop-only group tacacs+
aaa accounting system default start-stop group tacacs+
tacacs-server host
tacacs-server directed-request
tacacs-server key 1234567
Did i miss out any major config~?
It seems failproof to me but cant understand why it is not accessible via diff subnet 192.100.100.x ip
PLease advice
ighovwerha Tue, 08/24/2010 - 00:59
can you ping your acs from the core device when the IP are still as they were initially? If you can't then?
I suppose your acs is connected to you access switch:
my configs would be?
ACS Express - 5.0
IP address (   connected to fa0/1 on access switch
interface vlan 11 (
interface fa0/1 : switchport access vlan 10
                       switchpor mo access
interface fa0/23: switchport mode truk
                        switchport trun encap dot1q
interface vlan 10 :
interface vlan 11 (
interface vlan 10 (
interface fa0/23 : switchport mode trunk
                         switchport trunk encap dot1q
router rip
ver 2
no aut
net vlan 11
net vlan 10
NOTE: I decided not to use vlan 1 so that all unknown traffic still flows through vlan 1.
I hope this helps.
