Cisco Works LMS 3.2 web page...
Aug 23rd, 2010
Need your expertise, Installed Cisco Works LMS 3.2, over Windows 2003 SP2 with  IE version 6, noticed that by clicking on the Cisco Work icon, it pops up the Cisco Work page and ask the username and password but it shows an error on the page about the COOKIE is disable. Already enable the cookie from the Explorer, but still showing the cookie is diable,,, All other URL sites are working fine, except the Cisco LMS page..
What must be the problem????I already upgrade the IE6 to IE 7 and still having the same issue..
Joe Clarke Sat, 08/28/2010 - 18:18
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
This sounds like a browser security issue.  Try adding the LMS address to your list of trusted sites, then set the security level to Low for Trusted Sites.
cgarcia1971 Sun, 08/29/2010 - 00:37
Hi Joseph, Many thanks for your immediate reply. Regarding your advice, I already applied this thing on the Internet Browser options, by adding the LMS IP address on the trusted sites, and set the security level to Low..But it did not work, also applied on the Internet privacy setting by enabling the cookie and adjusting to low, also the same.
Anymore advice....
Joe Clarke Sun, 08/29/2010 - 00:42
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
Try using Firefox, or try using a different computer or account.  There may be some additional security restrictions applied to your account that are blocking cookies.
Joe Clarke Sun, 08/29/2010 - 09:28
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
That really leads me to think it's a security issue.  Are you using any host-based firewall or IPS system on this server? If so, try disabling it, and see if the problem persists.
cgarcia1971 Tue, 08/31/2010 - 01:09
Hi Joseph,
Many thanks for the help, it works with your advise (FireFox browser).
