877 Router IOS Issue
Answered Question
Aug 24th, 2010
Hey
I managed to wipe my IOS from my Cisco 877 Series router.
Now using TFTP I have managed to reload the software and boot up the Router (previously I was stuck in Rommom mode).
If I power the router off and turn it back on I am brought back to Rommom mode again and have to reload the IOS again.
What command do I need to use to make the newly downloaded bin file my main flash file that the router now boots from?
Thanks a mil
Correct Answer by Nagaraja Thanthry about 6 years 9 months ago
What option are you using when you TFTP the IOS to the router? Are you by
any chance using "tftpdnld -r" option? Please try the following:
Step 1: Upload the file via tftpdnld (like before)
Step 2: Boot the router
Step 3: Check the flash content and make sure that image is there.
Issue the command "show flash" at "Router#" prompt
Step 4: If the image is missing, copy the image
Issue the command "copy tftp flash" at "Router#" prompt
Step 5: Set the configuration register value to 0x2102
Issue the command "config-register 0x2102" at "Router(conifg)#" prompt
Step 6: Make sure that there is no boot statement in your configuration
Issue the command "show run | i boot system" command at "Router#" prompt and
make sure that there is no output for that command
Hope this helps.
NT
Overall Rating: 5 (2 ratings)
paolo bevilacqua Tue, 08/24/2010 - 02:31
  • Hall of Fame,
    Founding Member
A quick search would have revealed this to you.
config-reg 0x2102
And, you can boot from an image in flash at rommon prompt.
drikilbride Tue, 08/24/2010 - 02:34
I couldnt boot from Rommon mode as there was no bin image at all and an error kept
being thrown back. I will try that other command, thanks.
paolo bevilacqua Tue, 08/24/2010 - 02:42
  • Hall of Fame,
    Founding Member
What I mant, after you boot from TFTP, the image is copied to flash, no no further TFTP is necessary.
Please remember to rate useful posts clicking on the stars below.
drikilbride Tue, 08/24/2010 - 02:56
I reloaded my bin file from my tftp server, then went into config t when the router booted up and typed in config-reg 0x2102 as described.
I then did a copy run start.
When I powered off the router and powered it back on again I got
No bootable image: flash:/
Unable to open boot file
And I am back at the Rommon prompt again
Any ideas?
EPHRAIM MANI Tue, 08/24/2010 - 02:57
  • Bronze, 100 points or more
Please publish the output of
Step1:rommon 1 > dir flash:
change the registry value
Step2: rommon 1 > confreg 0x2101  or   rommon 1 > confreg 0x2102
boot the system
Step3: rommon 2 >
boot
Correct Answer
Nagaraja Thanthry Tue, 08/24/2010 - 05:30
  • Cisco Employee,
Hope this helps.
NT
drikilbride Tue, 08/24/2010 - 06:30
Ah thanks a mil, that worked perfectly! All back up and running again.
Related Content
