CUCM 7.1: Copying phone settings to Device Profile
Aug 24th, 2010
Is there any way in CUCM 7.1 to copy the settings (Lines/SDs) from a hard phone to a device profile?
For exapmple:
A users has a 7961 phone with to lines an 4 configurated SDs.
The user needs an 7961 device profile to log into other 7961s with his settings.
I want to create a device 7961 device profile without configuring every single setting from the phone, I just want them to copy.
Is this possible?
Overall Rating: 5 (1 ratings)
Aaron Harrison Tue, 08/24/2010 - 03:13
  • Community Spotlight Award,
    Member's Choice, May 2015
You can do this via BAT.
Go to Bulk Admin, User Device Profiles, Insert UDP.
Select 'Based on Devices Controlled by Users'
Hit Run Immediately/Submit.
What this actually does is looks at each user that has an associated phone, and then creates a UDP named username_phonename with the properties from that phone.
Obviously you have to have phones associated with the users, and it doesn't let you control which ones are converted - it does them all. Including, for example 'system' users you may have that have multiple phones associated to them or CTI ports. You'll probably have to go back and delete an amount of things that it configures...
Aaron
Please rate helpful posts...
holger.hahn Tue, 08/24/2010 - 06:16
OK that's a nice feature, but it creates device profiles
from EVERY user controlled device.
I only wont to create a FEW device profiles based on existing phones.
philip.e.denton Tue, 08/24/2010 - 06:20
  • Silver, 250 points or more
Just as Aaron indicated in his post.
If you're handy with Excel you could export the phones you want to 'duplicate' and then spin them around into a manual BAT import of UDPs.
Related Content
