NAC 4.7.2 OOB not started agent, ADSSO win2008 r2 enterprise
a.chernomazov
Hi.
Help me please to undestand.
I have OOB mode on next equipment:
CAM 4.7.2
CAS 4.7.2
2811 router
win2008r2 enterprise
Linksys srw2008mp
Catalist 4000
same hosts: winxp and win7 with nacagent 4.7.2
AD SSO on CAM started, ports on switch is controled.
On layer 3 network works fine, but nacagent on hosts don't started.
In your network.png screen capture you do not have "Enable L3 support" checked.  You need this checked if the computer is one or more L3 hop away from the NAC server.  Since you're running in OOB Real IP GW mode, I'm assuming this is the case.  You'll just have to run through these steps
1.  check the box
2.  reboot the NAC server
3.  try again
Could you provide a diagram of your scenario?  That would help out a lot.
Rob
Faisal Sehbai
Level 7
Level 7
Alexandr,
Please post screen shots of your CAS configuration pages (Network, Managed subnets, VLAN mappings if VGW, Static routes if RIP) and the Traffic policies page.
Faisal
I replaced the Catalyst 4000 to Catalyst 2950 but no change.
vlan mapping is not.
with best regards, Alexandr
1.  check the box
3.  try again
Rob
it's work.
