Finding CUCM unique CallID in ICM
Aug 24th, 2010
Hi all,
I am looking for a way to find the CUCM Call Identifier in the ICM database.
Is there any way I could do this just by  querying the ICM?
The pruporse of this query if because I am trying to match the t_Termination_Call_Detail records with the recorded call in the Verint Recording system.
Thanks in advance for your time.
Rodrigo
david.macias Tue, 08/24/2010 - 04:43
  • Blue, 1500 points or more
You will not find the CUCM ID in the ICM DB.  Verint usually uses a combination of the router call key and the router call key day.  Verint should know how to do this without any trouble.
david
rising437 Wed, 08/25/2010 - 07:47
Hi David,
Thanks for the answer.
Unfortunately I've been looking at the call details I find in the Verint 360 vCRM API (htt://serverName/ultra/DynaAsp/vCRMQuery.aspx)
and found only the Switch Call  ID. This API will serve me the purpose of searching a call by ID and playing the audio file, but unfortunately I don't see match between the Switch call ID and the the ICM call key or the router call key day.
maybe I could find it by using another API?
