Allow Cisco VPN Client Out
Answered Question
Aug 24th, 2010
We need to allow a computer on the inside of our network to connect to an outside network using Cisco VPN Client.  I have the external IP address of the outside network we are connecting to.  We have an ASA5520.  Would I setup a rule to allow TCP PPTP 1723 and IP GRE 47 to the external IP address I was given?  Would there be any other ports that would need to be allowed?
Thanks.
Correct Answer by Jennifer Halim about 6 years 8 months ago
If you would like to allow outbound Cisco VPN Client, then you would need to allow the following:
UDP/500
ESP
UDP/4500
plus you would need to allow "inspect ipsec-pass-thru"
Cisco VPN Client uses IPSec for VPN.
Hope that helps.
Overall Rating: 5 (2 ratings)
Correct Answer
Jennifer Halim Tue, 08/24/2010 - 05:29
  • Cisco Employee,
UDP/500
ESP
UDP/4500
Hope that helps.
