Another FAC post
jason.yipngow
Hi Guys,
I am having problems with using FAC on the UC520.
I have two ephone-dn's. One that is supposed to enter the authorization code and the other that is a vip caller (no auth codes).
I  am able to get the prompt for the user that is restricted and once  entered correctly the outgoing called is dialed. However the problem is that I  am also getting the prompt for the ephone that is setup to be the vip  caller. I've tried several different scenarios but can't seem to get it  work.
Essentially my goal is such that vip caller hits  the 60 pots dial peer immediately and the auth code call hits the 5500  voip dial peer then once entered correctly goes to the 60 pots dial  peer.
Thanks for any assistance in advance.
Below is my config:
dial-peer cor custom
  name internal
  name local
  name local-fac
dial-peer cor list call-internal
  member internal
dial-peer cor list call-local
  member local
dial-peer cor list user-local
  member internal
  member local
  member emergency
  member toll-free
dial-peer cor list call-local-fac
  member local-fac
dial-peer cor list user-local-fac
  member internal
  member local-fac
application
  service clid_authen_collect
   param uid-len 3
   param pin-len 3
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
username 201 password 123
username 201 autocommand exit
dial-peer voice 5500 voip
  corlist incoming call-local-fac
  description Local Calls
  destination-pattern 9[2-9]......
  session target ipv4:10.1.1.1
  incoming called-number 9[2-9]......
  dtmf-relay h245-alphanumeric
  codec g711ulaw
  no vad
dial-peer voice 60 pots
  trunkgroup ALL_FXO
  corlist outgoing call-local-fac
  translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
  forward-digits all
  no sip-register
ephone-dn 10
  corlist outgoing user-local
ephone-dn 12
  corlist outgoing user-local-fac
antyeung
Level 4
Level 4
Try making these changes and test-
ephone-dn 10
  corlist incoming user-local
ephone-dn 12
  corlist incoming user-local-fac
Anthony
5 Replies 5
antyeung
Level 4
Level 4
ephone-dn 10
ephone-dn 12
Anthony
jason.yipngow
Hi Anthony,
Thanks for the response.
This actually did work. The main problem was the fact that under the dn's I had put outgoing instead of incoming (lack of sleep, I think).
BTW, If I wanted to do this same process with the international dial-peer, how is the best way to handle the ephone-dn's in this case? We have 9011T and 91[2-9][2-9][2-9]....... as international numbers here.
Thanks again for the assistance.
I'll take a closer look and get back to you
(mobile)
Added user-international under the vip callers ephone-dn
Remaining users won't really need to dial international calls out.
Thanks again Anthony.
Best Regards.
When I first read this post on my mobile this afternoon I thought the previous recommendations didn't fix the issue. Good to hear you're all set.
Anthony
