Cisco 1811 - VPN Client - SSL / IPSec ? How To?
Aug 24th, 2010
I have a Cisco 1811 connected to the Internet and I'd like to establish VPN client connctions from outside. I'm looking for rookie step by step documentation on how to do that. I'd prefer to use ShrewSoft VPN client but the Cisco client is an option too. Also, later I need to establish Site-To-Site VPN between 1811 routers.
Please, if you know any documentation or guide available drop me a line.
Any help is appreciated
Jennifer Halim Tue, 08/24/2010 - 05:58
Here is a sample configuration for Site-to-Site VPN between 2 IOS routers:
Here is a sample configuration for Cisco VPN Client connection to IOS router (using Radius for authentication - you can change it to use LOCAL authentication if required):
Hope that helps.
