CCA 2.2.5 - Minor bugs/glitches
Aug 24th, 2010
I encountered 2 minor glitches when installing and using CCA 2.2.5
The 2 minor glitches were:
- CCA hangs on the licence agreement  first time after removing old version and installing 2.2.5.
Solution : Start Taskmanager, end CCA process and start CCA again
- CCA  doesn't find B-ACD files on the flashcard
Drag and drop  cme-bacd-3.0.0.2.tar on the UC and all is fine again. This issue was also around in 2.2.2 and 2.2.4.
Just to let you know.
With regards,
Marcel.
Glenn Quesenberry Tue, 08/24/2010 - 06:40
  • Cisco Employee,
Thanks for your candid feedback!  This type of information is very useful to our product teams and we do appreciate and use it.  We will make sure the CCA team is made aware of your feedback so that we can continue to improve CCA.
Thanks again!
Glenn
