ACE multicast MAC and new release A3(2.6)
vaba
Our ACE 4710 is setup to forward traffic to a CheckPoint Cluster IP as default gateway. Checkpoint working in active/active mode and using multicast mac address. This mean that mac address on CheckPoint Cluster VIP is 01.00.5e.xx.xx.xx. In release A3(2.6) says that is possible:
http://www.cisco.com/en/US/docs/app_ntwk_services/data_center_app_services/ace_appliances/vA3_x/release/note/RACEA3X.html#wp568729
Per CSCsr19346, the static arp command in configuration mode now allows the configuration of the multicast MAC address for a host. The ACE uses this multicast MAC address while sending packets to the host. This enhancement allows the support of deployments that involve clustering (for example Checkpoint clustering). A host can be assigned an multicast MAC address with the arp command. The ACE does not learn the multicast MAC addresses for a host.
I am using the command:
arp <CheckPoint Cluster ip> 01.00.5e.xx.xx.xx to set ip address and MAC address, but
ACE cannot ping the CheckPoint Cluster ip. ACE not creates sessions to CheckPoint Cluster ip and not generates any traffic. When I ping any physical address on CheckPoint firewall everything is ok. Is it possible to using CheckPoint Cluster ip for default gatawey and how to realize that?
Thanks in advance
4 Accepted Solutions
yushimaz
I checked the behavior in my lab. As you says, ping packets "generated by ACE" are dropped.
It doesn't depend on default gateway configuration. I can see this symptom without default gw
configuration.
I also checked several commands and found the following counter is increased.
Probably, verification check of mac address is failed.
ACE4710/Admin# sh np 1 me-stats -sicm | i MAC
MAC Lookup Error:                               148             0
It doesn't occur on transit (not generated by ACE) packets.
So, it seems that CSCsr19346 doesn't care packets generated by ACE.
If you want to ping from ACE, please contact TAC. It may be a new bug.
The following is my test result
### config
ACE4710a-yushimaz/Admin# sh run | i route
Generating configuration....
ip route 0.0.0.0 0.0.0.0 192.168.221.10  <<== default gw
ACE4710a-yushimaz/Admin# sh run | i arp
arp 192.168.221.10 01.00.5e.11.11.11  <<== static arp with mcast mac
arp 192.168.221.20 00.00.6c.11.11.11
### ping from server to default gw via(routed by) ACE
ACE4710a-yushimaz/Admin# sh logging
[snip]
%ACE-6-302026: Built ICMP connection for faddr 192.168.221.10/29549 gaddr 192.1
68.222.4/8 laddr 192.168.222.4/29549  <<== ACE created the connection
## capture trace
No.     Time                          Source                Destination           Protocol Info
     23 2010-08-25 03:57:18.494195731 192.168.222.4         192.168.221.10        ICMP     Echo (ping) request
Frame 23 (106 bytes on wire, 102 bytes captured)
Ethernet II, Src: Cisco_75:91:ed (00:0f:f7:75:91:ed), Dst: Cisco_fe:1b:01 (00:0b:fc:fe:1b:01)  <<== from server to ACE
802.1Q Virtual LAN, PRI: 0, CFI: 0, ID: 722
     24 2010-08-25 03:57:18.494213331 192.168.222.4         192.168.221.10        ICMP     Echo (ping) request
Frame 24 (106 bytes on wire, 102 bytes captured)
Ethernet II, Src: Cisco_fe:1b:01 (00:0b:fc:fe:1b:01), Dst: IPv4mcast_11:11:11 (01:00:5e:11:11:11) <<== from ACE to gw
802.1Q Virtual LAN, PRI: 0, CFI: 0, ID: 721
### ping from ACE to default gw
ACE4710a-yushimaz/Admin# sh np 1 me-stats -sicm | i MAC
ACE4710a-yushimaz/Admin# ping 192.168.221.10
Pinging 192.168.221.10 with timeout = 2, count = 5, size = 100 ....
No response received from 192.168.221.10 within last 2 sec
5 packet sent, 0 responses received, 100% packet loss
[snip]
%ACE-7-111009: User 'admin' executed cmd: clear logging
%ACE-7-111009: User 'admin' executed cmd: ping 192.168.221.10
  <<== not logged 'Built ICMP connection'
MAC Lookup Error:                               153             0  <<==
Yuji
I have the same issue, however slightly different results/equipment.
I'm using an ACE module in a 6500 split into to multi-context and have a cluster checkpoint upstream as the ACE contexts default gateway.
The ACE can poll the real interfaces of the checkpoint but not the VIP. Returning from the checkpoint it cannot poll any of the ACE interfaces or VIPS via icmp !!!
It is a major issue, as I have a default route pointing towards the Checkpoint VIP. However as the ACE is unable to ping the cluster IP, it is also unable to inject the static route that has been configured on the ACE.
I am running the latest code, as suggested by Cisco. Any other suggestions, or is it looking like a TAC.
Many thanks,
Jon Humphries
venkatkr
HI Vaba,
With CSCsr19346, multicast mac-address was supported with static arp command.  As a part of the fix, only through-the-box traffic scenario was addressed.
i.e, through the box multicast traffic will work fine in routed and bridged flows.
Multicast traffic originating from the box was NOT handled as a part of this fix.
As a result, we have a new issue opened CSCth45076   Not able to ping to multicast ARP address from ACE. However to make this fix, we have to make significant design change. So for now we decided not to implement this solution.
VK
Regarding ACE generated packets to mcast arp, CSCth44891(for module)/CSCth45076 (for appliance) are filed as internally found bug.
CSCth44891 was Closed(C) due to expected behavior(not supported). Currently, CSCth45076 is New(N) state but will be Closed(C).
CSCth44891/CSCth45076 Not able to ping to multicast ARP address from ACE.
ACE can handle multicast arp except for self generated. So, when you configure static arp and default route, it's listed on fib table
as below.
ACE20a/Admin# sh run | i 200
ip route 0.0.0.0 0.0.0.0 192.168.71.200
arp 192.168.71.200 01.00.5e.11.11.11
ACE20a/Admin# show ip fib
FIB for Context Admin (RouteId 0)
   Codes: H - host,   I - interface
          S - static,      N - nat
          A - need arp resolve,      E - ecmp
Destination         Interface         EncapId  Flags
0.0.0.0             vlan771                9   S [0xc]  <<==
ACE20a/Admin#
ACE20a/Admin# sh arp
Context Admin
IP ADDRESS      MAC-ADDRESS        Interface  Type      Encap  NextArp(s) Status
192.168.71.100  00.0b.fc.fe.1b.01  vlan771   VSERVER    LOCAL     _         up
192.168.71.200  01.00.5e.11.11.11  vlan771   GATEWAY    9         _         up <<==
192.168.71.250  00.0b.fc.fe.1b.01  vlan771   ALIAS      LOCAL     _         up
192.168.71.251  00.07.0e.0f.2c.a1  vlan771   INTERFACE  LOCAL     _         up
192.168.72.1    00.23.04.3d.a1.c9  vlan772   LEARNED    6      11652 sec    up
192.168.72.11   00.0c.29.b3.eb.4b  vlan772   RSERVER    4      36 sec       up
192.168.72.12   00.0c.29.e1.d4.dd  vlan772   RSERVER    3      36 sec       up
192.168.72.250  00.0b.fc.fe.1b.01  vlan772   ALIAS      LOCAL     _         up
192.168.72.251  00.07.0e.0f.2c.a1  vlan772   INTERFACE  LOCAL     _         up
192.168.72.254  00.00.6c.69.04.2a  vlan772   RSERVER    8      53 sec       up
192.168.73.251  00.07.0e.0f.2c.a1  vlan773   INTERFACE  LOCAL     _         up
192.168.73.252  00.1f.9e.1a.f4.37  vlan773   LEARNED    5      11573 sec    up
Total arp entries 13
ACE20a/Admin#
I also attached capture trace from server to client with default route.
Since there is no actual client, I can see icmp echo from server to ACE(vlan772) and from ACE to client(vlan771) only.
Yuji
6 Replies 6
yushimaz
configuration.
### config
[snip]
## capture trace
[snip]
Yuji
Many thanks,
Jon Humphries
as below.
          S - static,      N - nat
ACE20a/Admin#
Context Admin
ACE20a/Admin#
Yuji
venkatkr
HI Vaba,
VK
Thanks for all,
I am using arp command and now everything works for traffic passing through the ACE (only through-the-box traffic).
Venkatkr,
With my account I cannot see information for this bug (CSCth45076) .
I hope as a change in CSCth45076 status you will post some information
Thanks again
Hi again,
At the moment we are trying to configure ACE4710 by using user authentication with crypto authgroup”. We have imported root certificate and ACE certificate and everything is working just fine. The problem occurs when we are trying to configurate certificate revocation lists (CRLs) at the time of client authentication. ACE needs to access CA Server through Check Point Firewall cluster. On ACE we configured:
crypto crl CRL_LIST http://CAServer /CertEnroll/ CAServer.crl.
parameter-map type ssl SSL_PARAMETER_MAP
expired-crl reject
ssl-proxy service CLIENT_SSL
  crl CRL_LIST
  ssl advanced-options SSL_PARAMETER_MAP
For the tests we are using telnet 80 created from ACE, by using Check Point Firewall cluster IP address for default gateway. In this case there in no traffic generated from ACE to CA server and ACE cannot access http://CAServer/CertEnroll/ CAServer.crl. When we are using for default gateway on ACE ip address on active Check Point firewall we have access to CA Server on port 80 and telnet 80 is working. In this case we can download CRLs from the server.
Is this the same problem that the described one above by venkatkr, or this is a different one
