Cisco signature update site down?
Answered Question
Aug 24th, 2010
I just noticed that I haven't been getting my daily updates since Sunday.  I get the following error:
AutoDownload Job Report:
No files available for download.
Error: Unable to communicate with locator service to retrieve available files.
Has anyone else seen this?
Correct Answer by Dustin Ralich about 6 years 9 months ago
This seems to be an intermittent problem, becoming more visible today (not sure if it was occurring prior to today). If you urgently need a signature update file, for now (as a workaround), you can manually download the file from here:
http://www.cisco.com/cgi-bin/tablebuild.pl/ipsmc-ips5-sigup
And, place it in the CSCOpx\MDC\ips\updates directory on your CSM (Cisco Security Manager) system.
If you have time, if you could let us know what www.cisco.com resolves to on your CSM system. ? This may help confirm/track down the source of the issue. You should be able to do this from a Command Prompt (cmd.exe) on the CSM system using the nslookup utility. Example:
C:\nslookup www.cisco.com
Overall Rating: 5 (1 ratings)
Correct Answer
Dustin Ralich Tue, 08/24/2010 - 09:54
  • Cisco Employee,
Dustin Ralich Tue, 08/24/2010 - 10:11
  • Cisco Employee,
You're welcome Todd . Thank you for providing that output. As an alternative workaround (vs. manually downloading a signature definition update package file), you could also probably temporarily add a static entry for www.cisco.com to the WINDOWS\system32\drivers\etc\hosts file (on the CSM system). Example:
198.133.219.25 www.cisco.com
NOTE: A reboot of the CSM system (or, at minimum, a restart of the Cisco Security Manager Daemon Manager service) may be necessary for CSM to pickup on the static entry. Also, I wouldn't recommend this workaround (vs. simply manually downloading a signature definition update package). But, it may be an alternative option for you.
George Johnston Tue, 08/24/2010 - 12:23
I am getting the same error
nslookup www,cisco.com
Non-authoritative answer:
Address:  72.163.4.161
Aliases:  www.cisco.com, www.cisco.com.akadns.net
          geoprod.cisco.com.akadns.net
Try flushing the DNS cache on your server
H:\>ipconfig /flushdns
Windows IP Configuration
Successfully flushed the DNS Resolver Cache.
H:\>nslookup www.cisco.com
Address:  198.133.219.25
George Johnston Tue, 08/24/2010 - 12:39
Well that stinketh.  I am getting my updates now.  Looks like it's either static host entry or manual download..
skogut123 Thu, 08/26/2010 - 07:54
It looks like Cisco has resolved the issue.  My CSM system was able to download files late yesterday (8/25/10) afternoon.
