Upgrade VPN client from ASA
Aug 24th, 2010
I'm try to upgrade all my ssl vpn clients but for some reason its not seeing the upgraded software. I  used the followinig document but was unsuccessful.  I'm running version 8.05 on the firewall and ASDM 6.2(5).  Can anybody help with this?
lawchung Wed, 08/25/2010 - 16:06
If you want to upgrade your SSL VPN client then you can just upload the new package to the ASA and install it with the svc command. Next time your users connect to the ASA, it will push down the new client.
