Unable to delete files from Call Manager TFTP directory
Aug 24th, 2010
Hi, Does anyone know how to get around this problem where I cannot delete file "AppDialRules.xml" from CUPC tftp directory?
Tried both the GUI and CLI, the comands are accepted but the file never disappears.
I orginally added this file to make specific dial rules available to CUCIMOC clients, but I have since acheived want I need with the use of a translation rule on the server ie "\+61!" is all I need. Not sure why the CUCIMOC MOC  admin guide suggests the more complicated solution.
Gil
Matthew Kaufman Fri, 08/27/2010 - 08:16
  • Cisco Employee,
You can try to create a new empty AppDialRules.xml by re-running that "script" as you did when you initially installed CUCIMOC.
--Matt
mmoulson1 Tue, 05/08/2012 - 06:44
  • Bronze, 100 points or more
I’m trying to edit my CUPC/AppDialRules.xml but whatever I try it won’t replace the file and I can’t find a documented procedure (that works)!
Any ideas?
-I’ve tried with the TFTP service stopped.
-I’ve tried restarting the service after uploading.
-I’ve tried re-running the ‘cmterm-cupc-dialrule-wizard-0.1.cop.sgn’ after uploading
-I’ve tried re-running the ‘cmterm-cupc-dialrule-wizard-0.1.cop.sgn’ after uploading and stop/starting TFTP!
The most annoying thing is at some point I made it work as I have edit the rule from the default installed but the wizard!
Thanks in advance.
Matty
Related Content
