Cisco Client Not Getting DNS
Answered Question
Aug 24th, 2010
I have a cisco asa 5510 set up to work exactly like I want it to, with the exception that the clients dont get an dns server when they connect. I thought that the blurb below should take care of that, but unless i specify the dns on the client it does not work.  If I put the dns in the network config of the client, it works fine.  When I look at the client log, the DNS is set to, when the virtual adapter gets activated.  What am I missing?
group-policy (IGBVPN) attributes
dns-server value
vpn-idle-timeout 600
split-tunnel-policy tunnelall
default-domain value
tunnel-group (IGBVPN) type remote-access
tunnel-group (IGBVPN) general-attributes
address-pool IGBVPNPOOL
authentication-server-group IGBRADIUS
Correct Answer by praprama about 6 years 2 months ago
Have you specified this group-policy (IGBVPN) to be the "default group policy" under the tunnel group?
Can you paste the entire output of "show run all tunnel-group (IGBVPN)" ?
Overall Rating: 5 (1 ratings)
