Problems with EEM applet using cli command "dir flash:"
I'm trying to use an EEM applet to perform a "dir flash:" and then look to see if a specific file name resides in it with a regexp for for the file name but I can't seem to get th dir flash: to work.
event none
action 1.0 cli command "dir flash:"
action 2.0 puts "$_cli_result"
Then I manually run it using
event manager run appletname
I get a return of "Invalid input detected at '^' marker." where the ^ is pointing to the 2nd e in the word event.  This output is usually what happens when improper syntax is used but I don't believe I've made a mistake and in the past when an applet didn't run properly, it gave no indication to the monitor/console.  It just died.
Joe Clarke
You need to be enabled to look at file system details.  Try:
event none
action 1.0 cli command "enable"
action 2.0 cli command "dir flash:"
action 3.0 puts "$_cli_result"
Joe Clarke
event none
