Using Crypto Maps and IPsec Static VTI's on the same router
Aug 24th, 2010
Is it possible to configure both crypto maps and IPsec static VTI's on the same router? What platforms have this capability? What IOS version do I need?
uwkleinh Tue, 08/24/2010 - 15:02
Yes you can and as far as I know I dont think there is a hardware dependency.
VTI mode 'tunnel mode ipsec ipv4' was added in 12.3(14)T.
If you are mixing tunnel protection and crypto map ensure you use iskmp profiles to differentiate somehow that the tunnel IPSec connection is not prcessed on the crypto map!
Here is a rough example (fine tune it as needed):
crypto keyring key1
  pre-shared-key address key test123
crypto keyring key2
  pre-shared-key address key test777
crypto isakmp profile vpn1
   keyring key1
   match identity address
crypto isakmp profile vpn2
   keyring key2
crypto ipsec transform-set test esp-des esp-sha-hmac
crypto IPsec profile vpn-tunnel
set transform-set test
set isakmp-profile vpn1
crypto map mymap 1 ipsec-isakmp
set peer
set isakmp-profile vpn2
match address 177
interface Tunnel0
ip address
tunnel source
tunnel destination
tunnel protection ipsec profile vpn-tunnel
interface Ethernet4
ip add
crypto map mymap
Eugene Khabarov Tue, 03/24/2015 - 01:23
Самое главное отличие будет в том, что на удаленных устройствах в этом случае б в самом crypto-acl будут лишь два адреса, зеркальные адресам, указанным как tunnel source и tunnel destination на 2921. По идее, больше никаких изменений.
