Need to expand Routepattern/dialpaln
Currently have a dial plan to call between offices within a specific country. Now, I need to expand the RP to calling beyond offices to external numbers for both in/outbound.
DID are availbale....
Circuits in place
Gateway already configured
Call manager version 6.1.4.....
Can someone assist?....
Jaime Valencia Tue, 08/24/2010 - 17:47
That's a pretty open question...
If you've already configured the GW and you're going to use DIDs the only thing you might need to set is the significant digits and inbound CSS.
That's it, then just configure the phones. That's for inbound.
For outbound just configure the GW, configure a route group, then a route list and finally a route pattern.
Obviously CSS and partitions need to be configured accordingly to your needs.
If you have no experience designing a dial plan I strongly suggest you to read this.
If you don't know how to design a dial plan if will only cause you headaches in the future.
If this helps, please rate
stu_syn Wed, 08/25/2010 - 01:09
This email has been scanned for all viruses.
Please consider the environment before printing this email.
The content of this email and any attachment is private and may be privileged. If you are not the intended recipient, any use, disclosure, copying or forwarding of this email and/or its attachments is unauthorised. If you have received this email in error please notify the sender by email and delete this message and any attachments immediately. Nothing in this email shall bind the Company or any of its subsidiaries or businesses in any contract or obligation, unless we have specifically agreed to be bound.
KCOM Group PLC is a public limited company incorporated in England and Wales, company number 02150618 and whose registered office is at 37 Carr Lane, Hull, HU1 3RE.
118288 - KCOM Group UK Directory Enquiries. Calls will cost no more than 79p connection + 25p per minute including VAT from a KC or BT landline. Call charges from mobiles and other networks may vary. If you are calling from a mobile you will now receive your requested number via text message. You will not be charged for the text message.
