08-24-2010 06:12 PM - edited 03-06-2019 12:38 PM
Folks:
This request was sent to me.
Im trying to wrap my head around the requirement this person describes.
Any ideas would be greatly appreciated.
"It's a bit of a strange requirement and I can't get into specifically why we want it. We're not looking for a GRE or IPSec VPN - rather we want the properties of such a site to site VPN, however we want the transport to be SSL (not just TCP as I said earlier). Essentially we have other data (various types) that we want a black box to encapsulate in SSL."
08-25-2010 12:52 AM
I am having little bit knowledge on SSL Black box.
By using SSLBlackbox you can connect to remote servers or build your own secure servers.
[Refer Attached Diagram]
In particular, SSLBlackbox includes a client-side component to upload and download files using FTP / FTPS protocol. Other operations defined by FTP protocol specifications are supported as well. Note: FTPS (FTP over SSL) is not SFTP, which is SSH File Transfer Protocol
One of the recent additions to SSL/TLS family of protocols is Datagram TLS ( DTLS ), which is very similar to TLS. DTLS is used to protect UDP-based or other message-based network communications such as stream audio and video delivery. SSLBlackbox is one of the few solutions to provide client-side and server-side DTLS support.
Unlike symmetric encryption, securing communications with SSL/TLS doesn't require that the sides know the shared secret (password/encryption key). Also, the public key security lets each side examine authenticity of the other side and prevent man-in-the-middle attacks. Another benefit of SSL/TLS is that PKI infrastructure is a widely-used technology, so implementation and maintenance of SSL/TLS-based solutions are quite simple tasks.
SSLBlackbox does not use CryptoAPI, OpenSSL or other third-party encryption library. For certificate creation, management and validation SSLBlackbox uses PKI Blackbox, base functions of which are included with SSLBlackbox package.
SSLBlackbox has been tested with numerous client-side and server-side SSL implementations, including Internet Information Server and Java 2 EE. SSLBlackbox includes special workarounds for SSL/TLS implementation flaws, found in this software.
SSLBlackbox is offered as an individual package and as a part of Professional, Standard and Transports packages.
Why to choose SecureBlackbox: Resons are as follows:
Security
Flexibility
Easy to use architecture
Flexible support policy
Readiness for use
Affordable licensing schemes.
Hope this Helps
Srinadh.
