Agent calls are showing up on the default skill group (2397)
Aug 24th, 2010
We have ICM 7.2 with CTIOS 7.2.  The supervisors have a customized desktop (see snapshot).  There are calls that are showing up on the default skill group (00697605228).  Does anyone have an idea how these calls are going to the default skill group instead of the agent's assigned skill group?  Is this a routing issue with ICM?
david.macias Wed, 08/25/2010 - 05:52
  • Blue, 1500 points or more
Does this show up in the normal CTIOS desktop?  If not, then it's a problem with your custom desktop.
david
Richard Dumag Wed, 08/25/2010 - 13:57
David, it doesn't show on the normal supervisor desktop as it does not have the column for that field.
Geoff, looks like they are showing as inbound calls as well.  We have a support engineer that looked at the database and he said those are inbound calls that are hitting the default skill group.
We have a Cisco TAC case open on this but have not heard from the engineer assigned who's doing the research.
