OSPF and some type of NAT
Aug 24th, 2010
  • Bronze, 100 points or more
I have 10.0.21.X/24 as a HSRP btwn 2 core peers in OSPF Area 0 which is my server VLAN. We are relocating our HQ and moving servers in phases. We found one server whereby clients connect via IP rather than hostname and say has an IP of 10.0.21.100/24. I need to relocate this server to a new subnet in our new building which is 10.100.21.100/24 while at the same time ensuring clients can still reach it via 10.0.21.100. The new HQ is connect via WAN  which is Area 0 but the new server subnet 10.100.21.X/24 is in a non-zero Area.
How can I do this?
aamercado Mon, 08/30/2010 - 21:49
Below is the config I think would work. Here’s the traffic flow
1.       Lo75 is advertising specific route 10.0.21.75/32. Note that a couple hops away another router is advertising 10.0.21.0/24
2.       In my network, OSPF should route to Lo75 and hit G0/0 with cost 5 with NAT inside and PBR
3.       Assuming PBR takes precedence over routing table, then G0/0 send NAT to Lo0 for translation
4.       Lo0 translation from outside 10.0.21.75  to inside 10.100.211.34
5.       After translation, G0/1 or G0/0 send it back out straight to server base on recursive routing table lookup for 10.100.211.0 network which is also advertise via OSPF. Not too sure on my ACL or if I should just use one physical interface or 2?
Will this work before I test?
interface Loopback0
ip address 172.16.1.1 255.255.255.0
ip nat outside
interface Loopback75
description TO-ADVERTISE-TO-OSPF-FOR-SPECIFIC-HOST-ROUTE
ip address 10.0.21.75 255.255.255.255
interface GigabitEthernet0/0
description OUTSIDE INTERFACE
ip address 10.101.1.10 255.255.255.254
ip nat inside
ip policy route-map OUTSIDE
ip ospf network point-to-point
ip ospf cost 5
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
ip address 10.101.1.12 255.255.255.254
ip nat inside
ip policy route-map INSIDE
ip ospf cost 10
duplex auto
speed auto
media-type rj45
router ospf 1
router-id 10.101.1.10
log-adjacency-changes
network 10.0.21.75 0.0.0.0 area 0
network 10.101.1.0 0.0.0.255 area 0
ip nat outside source static 10.0.21.75 10.100.211.34
access-list 100 permit ip host 10.0.21.75 any
access-list 101 permit ip any any
route-map INSIDE permit 10
description INSIDE FROM 10.101.1.12 TO .13 ON DC-CORE-1-N7K
match ip address 101
set ip next-hop 10.100.211.34
route-map OUTSIDE permit 10
description OUTSIDE FROM 10.101.1.10 TO .11 ON DC-CORE-1-N7K
match ip address 100
