ssh and telnet to remote router
Aug 25th, 2010
hello I have a question know there sometimes someone how your SSH and telnet configure router to remote ?
all tips are welcome
Jennifer Halim Wed, 08/25/2010 - 04:19
Do you mean that you are trying to SSH/telnet to the router remotely?
If that is the case, by default SSH/telnet should be enabled unless you disable it.
Check the configuration under "line vty 0 4", you should have a line that says "transport input all" which allow both SSH and telnet.
For SSH, you would need to generate RSA keypair before you can SSH to it.
For telnet, you can just telnet to it directly.
Another configuration that you might want to check is if there is any ACL applied to the interface, or line vty, and/or if there is any Zone base FW configuration.
Hope that helps.
pcfreak49 Wed, 08/25/2010 - 05:06
yes that wants try on the line vty 0 4 transport input telnet SSH
the RSA key are generate on 1024
with telnet am not possible I remotly
I hope that someone can help me please
Paolo Bevilacqua Wed, 08/25/2010 - 05:15
You have asked this same question already, but you have failed to explain what do you want to do actually.
You also have receivied a very valuable answers, again you have failed consider or understand.
Please do not open thread doplicates, and explain what you want to do in plain english.
pcfreak49 Sat, 08/28/2010 - 06:02
I none English but Dutch for becomes the text translates
who can help me for configuring remote telnet and SSH
all tips are most welcome
pcfreak49 Sun, 08/29/2010 - 00:04
here my running-config are
if there is must be adapted must
it would be possible me that to leave
to know because will very gladly have that it works it is for my studies
kind regards
Paolo Bevilacqua Sun, 08/29/2010 - 10:27
interface GigabitEthernet0
no ip virtual-reassembly
no zone-member security out-zone
interface Vlan1
no ip flow ingress
no zone-member security in-zone
no ip tcp adjust-mss 1452
pcfreak49 Mon, 08/30/2010 - 11:19
I can ping from outside do public address
I want telnet and SSH on do Cisco router for remote in at lay
pcfreak49 Tue, 08/31/2010 - 14:20
I have telnet and SSH necessary because have Friday lesson please help me
pcfreak49 Tue, 08/31/2010 - 23:42
the problem is that the port of telnet/23 and ssh/22 does not want configure open none you no access-list and ip nat?
kind regards
