08-25-2010 02:44 AM - edited 03-03-2019 06:02 AM
I'm trying to convert Cat OS to IOS, below are some info:
Hardware information:
Mod Slot Ports Module-Type Model Sub Status
2 2 2 1000BaseX Supervisor WS-X6K-S2U-MSFC2 yes ok
16 2 1 Multilayer Switch Feature WS-F6K-MSFC2 no ok
Mod Module-Name Serial-Num
2 SAL08218H90
16 SAL08218CN0
Mod MAC-Address(es) Hw Fw Sw
2 00-08-7d-cb-ac-ca to 00-08-7d-cb-ac-cb 5.0 7.1(1) 7.6(7)
00-08-7d-cb-ac-c8 to 00-08-7d-cb-ac-c9
00-1e-79-9c-a0-00 to 00-1e-79-9c-a3-ff
16 00-0f-90-98-fa-40 to 00-0f-90-98-fa-7f 2.6 12.1(20)E3 12.1(20)E3
Mod Sub-Type Sub-Model Sub-Serial Sub-Hw Sub-Sw
2 L3 Switching Engine II WS-F6K-PFC2 SAL08218AZ3 3.4
Current OS of Supervisor Engine: cat6000-sup2k8.7-6-7.bin
Current OS of MSFC2: c6msfc2-jsv-mz.121-20.E3.bin
To be upgrade to IOS: c6sup22-js-mz.121-23.E4.bin
I have followed the procedure on Converting Hybrid OS to Native IOS from the web link below:
After the switch reboots, it prompts error:
"Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) c6sup2_sp Software (c6sup2_sp-SPV-M), Version 12.1(27b)E4, RELEASE SOFTWARE (fc3)
Technical Support:
http://www.cisco.com/techsupport
Copyright (c) 1986-2008 by cisco Systems, Inc.
Compiled Fri 29-Feb-08 14:16 by hqluong
Image text-base: 0x40020EF4, data-base: 0x4095A180
00:00:03: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bo otstrap, Version 12.1(1 1r)E1, RELEASE SOFTWARE (fc1)
TAC Sup port: ht tp:/ /w w w.cisco.com/tac
Copyright (c) 20 02 by cisco Systems, Inc.
Cat6k-MSFC2 platform with 262144 Kbytes of main memory
Download Start
! ! !*** Mistral Interrupt on line 4 ***
System memory 1 bit ECC correctable error interrupt ..
PC = 0x8000840c, Cause Reg = 0x4400, Status Reg = 0x3041c003
Please assist to advise any idea/solution to resolved this. Many Thanks.
08-25-2010 12:22 PM
Hey Romel,
This looks like a potential hardware failure with the memory on the SUP, likely specific to the RP side -
Do you see this error each time the SUP tries to boot? You'll probably need to replace the SUP (at the very least, the MSFC). Hope this helps.
Brandon
08-25-2010 07:32 PM
HI Brandon,
Thanks for the reply.
Yes, I do encounter this error everytime I reboot the Sup with IOS. I have another spare of SUP with the same model.
I will try to convert the spare SUP and hope it works. Will let you know of the outcome.
Best Regards,
Romel
08-26-2010 02:42 AM
Hi Brandon,
As I mentioned, I tested the spare SUP and it work just fine. Indeed it was a hardware problem and is now on the process to be replaced.
Thank you very much for the assistance.
Best Regards,
Romel
