DMZ Link bandwidth/multihoming/equal cost loadsharing/balancing
Answered Question
Aug 25th, 2010
Friends,
can you suggest best ways to load balancing in a multihoming scenarion in which i have multiple links from different service providers, all of them are equal bandwidth links.?
what is the difference between load balancing and load sharing?
where is dmz-link bandwidth is used.is it applicable to equal cost link load balacing in multihome scenarion?
thanks in advance for your help as usual
regards
V
Correct Answer by Giuseppe Larosa about 6 years 8 months ago
Hello Porkovan,
natural use of dmz-link bandwidth is with links of different speeds leading to the same peer AS
if all your links are of equal speeds you don't need it
you will need two commands
router bgp XXX
maximum-paths N
an hidden command in order to install routes coming from different peer AS
bgp bestpath as-path multipath-relax
Note:
if you plan to accept multiple full BGP tables the possible impacts of BGP multipath on memory use of routing table and CEF tables has to be taken in account.
The above setup can be a safe and wise move if you are accepting only a default route or few IP prefixes from each provider.
Impact may vary also depending on platforms you use: running out of CEF tables on a C6500 is dramatic for example.
Hope to help
Giuseppe
Overall Rating: 5 (1 ratings)
Correct Answer
Giuseppe Larosa Wed, 08/25/2010 - 04:09
  • Hall of Fame,
    Founding Member
Hello Porkovan,
router bgp XXX
maximum-paths N
Note:
Hope to help
Giuseppe
