Cisco VPN Client + Password + Token
Aug 25th, 2010
how can i configure a cisco vpn client security with the password+tokennumber
With SSL VPN and AnyConnect i can configure a secondary authentication, this works. On a customer site i have seen that this is also possible with the vpn client?
For example:
Cisco VPN Client 5.x
Username: testuser
password: ldappassword+tokennummer
From here i have read that double authentication not work on cisco ipsec vpn client http://www.cisco.com/en/US/docs/security/asa/asa82/release/notes/asarn82.html#wp383156
But why this works on customer site? I have no access to this firewall so i`m not able to see the config.
I use 5520 8.3(1) .
regards
Jason
Asim Malik Wed, 08/25/2010 - 08:51
  • Cisco Employee,
Hi Jason,
Its not supported. Not sure how it is working on customer setup. You can compare the working and non working configs and see what is the difference.
Asim
