How do I provide Dial tone on E&M T1
Aug 25th, 2010
I have 1 third party IVR connected to an H323 gateway via a Digital T1 E and M winkstart port.  I can make calls to the IVR but when a person tries to zero out, it tries to transfer call but it is not working.
The vendors says that I need to provide dial tone. How would I do that?
controller T1 0/0/1
clock source internal
ds0-group 0 timeslots 1-24 type e&m-wink-start
description IVR
This feature worked when connected to a MGCP gateway in a 4.2(3) environment.
Overall Rating: 3.2 (5 ratings)
Paolo Bevilacqua Wed, 08/25/2010 - 07:50
  • Hall of Fame,
    Founding Member
To my knowledge, no dial-tone is ever provided in E&M.
Beside, if the call is completed already, no dialtone should be ever further provided.
Likely there is another cause than what the IVR vendor is claiming.
thomuff Thu, 08/26/2010 - 12:23
You are correct.
Here is what we have found.
The IVR is dialing the five extension ie 70002. However, the gateway is receiving the 7 and then trying to match dial peers on the seven. It is like it is not waiting for the other digits
Have any ideas.
Paolo Bevilacqua Thu, 08/26/2010 - 12:43
  • Hall of Fame,
    Founding Member
Are you using MGCP or H.323?
In either case, one should look at your dialplan configuration.
To the person that rated my post above a "3", since the information I gave is 100% correct and made with the will to help, please avoid subrating my posts in the future.
thomuff Wed, 09/01/2010 - 10:45
Here is what we found.
The VRU was performing a hook flash and then sending DTMF digits.  So, we had to install a TCL script on the gateway in order for the blind transfer to work.
frlindse Wed, 09/01/2010 - 10:59
  • Cisco Employee,
In the debugs you should see the
hookflash from the IVR, check the duration.  The defa
ult hookflash timer is 150-1000 msec, if it's shorter it will be ignored, if
longer it will be considered a disconnect
