Problem AP1522 with WLC 4402
Answered Question
Aug 25th, 2010
HI,
I Have a problem installing an AP 1522 to WLC 4402, this is not recognized, What can be ? check all connections and everything is fine
thank for help me
Correct Answer by Stephen Rodriguez about 6 years 6 months ago
For MESH AP, you need to add the mac address to the MAC filter under the Security Tab.  For RAP, you can use the ethernet mac, for a MAP you should use the 5Ghz radio mac
Overall Rating: 5 (1 ratings)
Correct Answer
Stephen Rodriguez Wed, 08/25/2010 - 07:37
Related Content
