Need Commands 2 Tshoot OQD on PO on 3 Stacked 3750E
Aug 25th, 2010
We walked all interfaces on the LAN. We have high OQD on 8 Gb/s PO to include OQD on the physical interfaces spread across 3 3750 E stacked switches. The througput is only ~2Gb/s and there isn't ever more than two servers on one ASIC. These switches are wired copper to two stacked 3110 inside an IBM blade center. The blade center has an Abnormal Temp Detected error on a DIMM but I don't believe this to be the source of the problem as there aren't any IQDs on the blade center switch stack. I need commands to view parameters on the 3750E stack. Anybody have some good commands to look into this deeper than sh po# int, or sh platform? I have by the end of the day or the new servers are migrated off the switch.
Thanks!
Matt
