6500 VSS and VPN (IPSEC-3) port adapter
Aug 25th, 2010
From what I have found the VPN (WS-IPSEC-3) port adapter (on a WS-SSC-600) is not supported if you decide to turn the 6509-E into a VSS system.  Is this correct?  Thanks!
Jerry Ye Wed, 08/25/2010 - 08:39
It is not supported as of now. You might want to contact your Cisco sales team about future roadmap.
jerry
canero Fri, 11/02/2012 - 06:23
Need the same information for a VSS design (for IPSEC-2G card), but still could not find information about whether it is/will be supported or not. Could you get any information from Cisco sales team about the roadmap?
Best Regards,
cliffgoniea Wed, 01/20/2016 - 08:47
Here is what we have recently been able to achieve:
We have two sets of VSS 6509s with WAN interconnectivity between them over a microwave radio.
We have one SSC-600 and one IPSEC-3 module in each of the four (4) chassis.
We are encrypting all traffic that traverses the WAN connection.
Our problem: We can only specify the use of one IPSEC module or the other in each of the VSSs. If the chassis that has the in-use IPSEC module goes down, we will lose all connectivity.
Does anyone know the path I should take to enable the redundancy of the IPSEC modules?
Thanks!
Cliff
