CSS: Different Ping Sizes
Aug 25th, 2010
Hi, What I'm seeing is that some IP's are set for an MTU of 1472, while others are 34032 or 65500. How is this set and how can it be modified?
For Example:
circuit VLAN55
  ip address 10.1.55.5 255.255.255.192 <----------- Can send ping of 34032 bytes
    ip virtual-router 55
    ip virtual-router 150 priority 105 preempt
    ip redundant-interface 55 10.1.55.4 <------------- Can only send ping of 1472 bytes
circuit VLAN255
  ip address 10.1.55.66 255.255.255.192 <----------- Can send ping of 34032 bytes
    ip virtual-router 255
    ip redundant-interface 255 10.1.55.65 <------------- Can only send ping of 1472 bytes
circuit VLAN256
  ip address 10.1.55.130 255.255.255.192 <----------- Can send ping of 34032 bytes
    ip virtual-router 254
    ip redundant-interface 254 10.1.55.129 <------------- Can only send ping of 1472 bytes
The VIP’s and real IP’s of the servers are exhibiting similar results.
Thank you in advance!
MD
yushimaz Wed, 08/25/2010 - 19:39
  • Cisco Employee,
Unfortunately, there is no option to enable ping more than 1472 bytes on redundant-interface.
CSS supports packets over 1500 bytes on the circuit ip address and mgmt ip address, but
there is a limitation on the redundant-interface ip address or any other ip address.
data(1472bytes) + icmp header(8bytes) + ip header(20bytes) = 1500 bytes
Since redundant-interface and vip address are virtual address, the behavior is different from
circuit ip address and mgmt address. You can check with 'shell 1 1 ifShow | grep Internet'
command whether the ip address is supported more than 1500 bytes or not
CSS11503(debug)# shell 1 1 ifShow | grep Internet
     Internet address: 1.169.0.13  <<==  Ethernet-Mgmt
     Internet address: 127.0.0.1  <<== loopback
     Internet address: 192.168.78.250  <<== circuit ip address
<<== ip address of redundant-interface is not present
<<== vip address is not present
CSS11503(debug)#
CSS11503(debug)# sh run circuit
!************************** CIRCUIT **************************
circuit VLAN777
  ip address 192.168.77.250 255.255.255.0
    ip virtual-router 1
    ip redundant-interface 1 192.168.77.200
CSS11503(debug)# sh run owner
!*************************** OWNER ***************************
owner test
  content test
    vip address 192.168.77.100
    add service sv1
    add service sv2
    active
CSS11503(debug)# sh boot-config
!************************ BOOT CONFIG ************************
  ip address 1.169.0.13
  subnet mask 255.0.0.0
  primary boot-file sg0820402
  primary boot-type boot-via-disk
CSS can handle and loadbalance fragments to vip address with 'tcp-ip-fragment-enabled'
and udp-ip-fragment-enabled' command on global configuration mode, but it doesn't affect
icmp packets.
Yuji
