Dialable intercom not working yet
Aug 25th, 2010
  • Bronze, 100 points or more
It sends *DB out my Sip trunk so I'm getting a busy signal immediatly. What can I do to keep it inside? Also, it was trying to register the dn's with my service provider, so I manually cleaned that up. I'm very excited for this feature to work with CCA, but I think I need a tweak yet.
Stephanie
antyeung Thu, 08/26/2010 - 20:37
Hm... doesn't sound right that it would send *DB to your SIP provider.
Can you provide your 'show run' excluding the pwds and enable the following debugs when you try to use dialable intercom?
Anthony
SHeidemann Fri, 08/27/2010 - 14:11
I tried to send this over as well
antyeung Fri, 08/27/2010 - 14:36
We found the problem and we are actively working on resolving this. As a workaround you would need to go into the CLI and shutdown one of your dial-peers.
Can you post your 'show run' output excluding the pwds? I'll be able to tell you which dial peers to shutdown.
Anthony
antyeung Fri, 08/27/2010 - 14:40
Does your SIP trunk provider support star codes? If not you'll need to shut down these dial peers for dialable intercom to work in the interim-
dial-peer voice 1001
shut
dial-peer voice 1002
shut
Anthony
SHeidemann Fri, 08/27/2010 - 14:51
Seems to have done the trick. Thank you for the help. I'm not positive if my provider supports star codes, but most likely not.
Again
Thanks!
antyeung Sun, 08/29/2010 - 17:05
NP. Good to hear you're all set.
-Anthony
