Cisco Nac Error message
Aug 25th, 2010
Hi.
Today I found one of my standby NAC servers is down. The power switch in front shows amber and the power supply behind too shows amber. When accessing through serial i see the following output. What could be wrong?
Prasanth George
Faisal Sehbai Wed, 08/25/2010 - 13:17
Prashanth,
You seem to have ended up in the iLO Management. Can you reboot the device and see if it boots up correctly?
Faisal
Prasanth Mathews Wed, 08/25/2010 - 22:47
I did remove the power and reconnected the power. Still it ends in ILO. Even if i continously keep pressing the power button in front, the light keeps remaining amber. Its model is 3140 CAS server
Any suggestions?
Prasanth Mathews
