CSM 3.3.1 having MANY issues
Aug 25th, 2010
We have two TAC cases open.
This is what we are experiencing.
1. We did a job that has rules for ICMP as echo-reply and echo-request. The config sent out mask and mask-reply
2. If a device is not selected for deployment and you get to the delpoyment screen and select the device for deployment there it does not deploy. Only if you select the device for deployment first does it work.
3. A Config was deployed. We edited it. The edits did not take.
We have had many more issues like this. Any one else experiencing odd isues with this product??
