Update WCS installation
Aug 25th, 2010
I have WCS running at the version 6.0.132; would like to upgrade to latest version 6 available; downloaded software and started installation. At the point where installation should find the previous version, the messages says that there is none to find. The current installation is on D drive and installation wizard goes by default to C drive. If you follow the installation wizard there is step where you can choose installation directory but not sure why wizard did not find existing installation.
I would like to keep existing database and just perform upgrade - what your suggestions would be in this case?
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
