CUCM BAT Field of Device Profile Failure
Aug 25th, 2010
Getting the following errors in the Logs and the screen shot of the error in the Job
____________________________________________________________________________________________________________________________
TelecasterSubscribedService as T WHERE my_lower(D.Name) = my_lower('1260') AND D.pkid = T.fkDevice;]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.560 CCM|DB: SQL2[SELECT T.pkid, T.fkDevice, T.serviceURL, T.fkTelecasterService, T.uRLButtonIndex, T.URLLabelASCII, T.URLLabel AS UnicodeUrlLabel, D.Name as DeviceName FROM Device AS D, TelecasterSubscribedService as T WHERE my_lower(D.Name) = my_lower('1260') AND D.pkid = T.fkDevice;]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.560 CCM|DB: SQL1[SELECT D.name, D.pkid, D.xml FROM Device AS D WHERE D.tkDeviceProfile = 0 AND D.name = '1260']|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.569 CCM|DB: SQL2[SELECT D.name, D.pkid, D.xml FROM Device AS D WHERE D.tkDeviceProfile = 0 AND D.name = '1260']|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.569 CCM|DB: SQL1[select distinct blfindex, label, labelascii, blfdestination, dnorpattern, devicename, BLFSDOptionBitmask  from busylampfield_cmvw  WHERE tkDeviceProfile = 0 AND devicename = '1260' ORDER BY blfindex]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.579 CCM|DB: SQL2[select distinct blfindex, label, labelascii, blfdestination, dnorpattern, devicename, BLFSDOptionBitmask  from busylampfield_cmvw  WHERE tkDeviceProfile = 0 AND devicename = '1260' ORDER BY blfindex]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.580 CCM|DB: SQL1[select * from directedcallparkblf_cmvw WHERE tkDeviceProfile = 0 AND devicename = '1260' ORDER BY blfindex]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.589 CCM|DB: SQL2[select * from directedcallparkblf_cmvw WHERE tkDeviceProfile = 0 AND devicename = '1260' ORDER BY blfindex]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.590 CCM|DB: SQL1[ SELECT DISTINCT EU.userid, EUL.enableCUPS  FROM          DeviceNumPlanMapEndUserMap AS M,        EndUser                    AS EU,  OUTER EndUserLicense             AS EUL  WHERE M.fkDeviceNumPlanMap = 'bc7ad2b4-cab2-f03e-0084-31b55ad95dbb'
AND M.fkEndUser = EU.pkid    AND EUL.fkEndUser = EU.pkid]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.626 CCM|DB: SQL2[ SELECT DISTINCT EU.userid, EUL.enableCUPS  FROM          DeviceNumPlanMapEndUserMap AS M,        EndUser                    AS EU,  OUTER EndUserLicense             AS EUL  WHERE M.fkDeviceNumPlanMap = 'bc7ad2b4-cab2-f03e-0084-31b55ad95dbb'    AND x = EU.pkid    AND EUL.fkEndUser = EU.pkid]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Detailed><MASK::ffffff>
08/25/2010 14:11:22.626 CCM|dBProcs - SUCCESS read one device|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Arbitrary><MASK::ffffff>
08/25/2010 14:11:22.630 CCM|DbMobility:
failed to find dual mode with pkid [7dc7289b-73ee-dd9b-712d-e0b266f96497]|<CLID::StandAloneCluster><NID::192.168.10.1><LVL::Error><MASK::ffffff>
08/25/2010 14:11:22.630 CCM|DeviceManager::DmResetDeviceReq - No registered Device found in this node. Wait for it to register. DeviceName=1260
______________________________________________________________________________________________________________________________
Any idea.,
haroon.rasheed Wed, 08/25/2010 - 16:13
When ever i try to update the fields in the device profile of 300 users , i came across the attached error message and when i captured the logs i see the output above.
Any help in this regard would be appreciated.
