08-25-2010 03:27 PM
I am trying to import certain routes from the Global Routing Table to a VRF table without any success. Could you help? Thanks.
CAR_A#sh ip route
O IA 172.23.0.0/16 [110/2] via 10.68.0.3, 00:25:21, FastEthernet1/0
CAR_A#sh run | in ip prefix
ip prefix-list data-center-net seq 15 permit 172.23.0.0/16 le 32
CAR_A#sh run | b route-map data-center-net
route-map data-center-net permit 10
match ip address prefix-list data-center-net
CAR_A#sh run | b ip vrf data
ip vrf data
import ipv4 unicast map data-center-net
CAR_A#sh ip route vrf data
Routing Table: data
C 10.68.31.0 is directly connected, FastEthernet0/0.2
As you can see, the vrf data routing table is not learning 172.23.0.0/16 imported from the Global Routing Table.
08-26-2010 03:23 PM
Hi Kevin
Can you post the config !!
And also please can you share the output of
1] Sh ip vrf (name) detail
2] Sh ip bgp vpnv4 vrf (name)
And check whether RD has configured under your vrf.
Chetan Kumar
08-30-2010 01:14 PM
Chetan,
I finally got it working by just reloading the router. Feels like troubleshooting Windows product now - reboot first!
Now, I got the import working. I am wondering if there is a dynamic export feature to export VRF routes into Global Routing Table.
Here is the problem. All sites are connected to a MPLS VPN cloud. Networks located at the Data Centers are in the Global Routing Table. Branch offices have several VRFs using VRF-lite, for example, Engineer VRF and Finance VRF. All VRF-lites are also configured on the data center WAN edge routers. So far I have managed to import data center networks into both Engineer VRF and Finance VRF using "import ipv4 unicast" command. How do I export Engineer networks and Finance networks to the data center? "export ipv4 unicast" does not exist.
08-31-2010 10:53 AM
I finally tried GRE based route leaking on the same router. I can finally have connectivity between a VRF and the Global Routing Table.
interface Loopback100 ip address 192.0.2.1 255.255.255.255 ! interface Tunnel100 ip address 192.0.2.129 255.255.255.252 tunnel source Loopback100 tunnel destination 192.0.2.2 ! router ospf 100 network 192.0.2.129 0.0.0.0 area 0 !
interface Loopback101 ip address 192.0.2.2 255.255.255.255 ! interface Tunnel101 ip vrf forwardingip address 192.0.2.130 255.255.255.252 tunnel source Loopback101 tunnel destination 192.0.2.1 ! router ospf 101 vrf network 192.0.2.130 0.0.0.0 area 0 However, this might not be an ideal solution for the data center as it routes all traffic thru a GRE tunnel. I will try the cross-over cable trick next.
