08-25-2010 03:28 PM - edited 03-16-2019 12:28 AM
Hey everyone, I do not have a CUCM in front of me right now, but does anyone is there is an interdigit timeout for MGCP controlled trunks? (QSIG, PRI, CAS, etc).
Im having a interdigit timeout issue I believe or I need switch my MTP sources from CUCM to the router for better performance. I posted another thread about this last week, but had another idea with MGCP. Im not sure if there is a service parameter for this or not.
CUCM 5.x (eeck!)
Thanks!
08-30-2010 12:17 PM
Check the T302 timer this will adjust the interdigit time out for the whole cluster. you can find it under Service > Service Parameters
Be careful. Do not set the interdigit timeout value too low, otherwise the user does not have enough time to enter the digits while calling
09-01-2010 09:01 AM
I dont think the T302 timer has an effect on DTMF coming *IN* from a digital source does it? We checked the delays and saw from a Cisco IP phone, it was 60ms. From PSTN is was 105ms. The DTMFs work, just need to type them in slow... which reducing the timer would effectly make it worse I believe. There would no little to no gaps between the digits entered.
