ACS 5.1 not logging authentication attempts
Aug 25th, 2010
I set-up an ACS server to authenticate users using AD.
It works fine for authenticating the users login attempts
but when I go to check the logs for failed and successful logins
the logs do not appear.
Any idea what could be causing this?
Is there some sort of process or service I should check or restart?
Przemyslaw Konitz Thu, 08/26/2010 - 05:23
Once I had a similar issue. Everything worked fine except logging for tacas authentication etc. I checked
show application status acs
and one process "view-logprocessor" was not running. After restarting the ACS and doublecheck that all processes were up everything returned to normal.
regards
Related Content
