Error Message on CUE with %SYS-3-TIMERNEG: Cannot start timer
Aug 25th, 2010
hi,
I am getting this error message on the CUE every 10 secs. How do I stop this message appearing this meessage?
Message details-
A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:00.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1486548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:10.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1496548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:20.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1506548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:30.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1516548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
Aug 26 03:01:40.655: %SYS-3-TIMERNEG: Cannot start timer (0x8645B0A8) with negative offset (-1526548). -Process= "TTY Background", ipl= 0, pid= 41,  -Traceback= 0x82A9ACDCz 0x82A99B60z 0x813A6B4Cz 0x813A6080z 0x813A7BD8z 0x813A8460z 0x813A87B0z 0x802BE3B0z 0x802C1050z
regards,
arman
antyeung Thu, 08/26/2010 - 14:50
  • Bronze, 100 points or more
Are these messages seen when you are on the CLI of CME or when you are sessioned into CUE?
-Anthony
MD ARMAN HOSSAIN Thu, 08/26/2010 - 15:55
Hi Anthony,
These messages are seen when I am on the CLI of CUE.
Arman
antyeung Thu, 08/26/2010 - 20:32
It would be best to open a TAC case to diagnose this issue. To clarify are there any symptoms that are service impacting besides these error messages appearing on the console when session into cue?
Anthony
antyeung Thu, 08/26/2010 - 21:15
It's always good to be proactive :-)
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} Opening a TAC case would be best to understand those error messaages.
Anthony
MD ARMAN HOSSAIN Thu, 08/26/2010 - 21:18
I have just did a factory reset on this device to install form the scratch to see whether that message come up. If it doesn't show up then it would be an issue with my config. So far it looks good.
antyeung Thu, 08/26/2010 - 21:20
That's one stealth config you got...
Anthony
