08-25-2010 11:07 PM - edited 03-11-2019 11:30 AM
Hello everyone,
I am trying to use snmp-map feature to block specific snmp version and somehow it doesn' t work . Am I missing something , or got it wrong ?
My only thought is that command snmp-server host xxxxx overrides the snmp-map but then - waht is the sense of snmp map ?
Info:
ASA 5510, image asa821-11-k8.bin
My snmp station from which I query the ASA is 2.2.2.2
snmp-map no-v3-here
deny version 3
# sh run access-list no-v3
access-list no-v3 extended permit udp any any eq snmptrap
class-map snmp-block-v3
match access-list no-v3
policy-map no-snmp-v3
class snmp-block-v3
inspect snmp no-v3-here
service-policy no-snmp-v3 interface outside
I tried specifying version 2c of snmp, applying to global service policy - no help .
I can still query this ASA by all snmp versions that are enabled on it.
SNMP configs:
nmp-server group V3-auth v3 auth
snmp-server group v3-priv v3 priv
snmp-server group v3-noauth v3 noauth
snmp-server user AUTH V3-auth v3 encrypted auth md5 xxxxxxxxxxxxxxxxxxx
snmp-server user Mambo v3-noauth v3
snmp-server user very_secure v3-priv v3 encrypted auth md5 xxxxxxxxxxxxxxxxxxxxx
snmp-server host outside 1.1.1.1 community ***** version 1 udp-port 162
snmp-server host outside 2.2.2.2 version 3 very_secure udp-port 162
no snmp-server location
no snmp-server contact
snmp-server community *****
snmp-server enable traps snmp authentication linkup linkdown coldstart
snmp-server enable traps syslog
no snmp-server enable traps ipsec start stop
no snmp-server enable traps entity config-change fru-insert fru-remove
no snmp-server enable traps remote-access session-threshold-exceeded
snmp-server enable
snmp-server listen-port 161
Thanks.
Solved! Go to Solution.
08-26-2010 09:13 AM
Hi Yuri,
The snmp-map/inspection is only applied for SNMP traffic passing *through* the ASA (i.e. the client and server are on opposite sides of the ASA). To disable SNMPv3 support for traffic *to* the ASA, you can adjust the snmp-server host and snmp-server group commands to not include v3.
Hope that helps.
-Mike
08-26-2010 09:23 AM
Are you trying to deny snmp version 3 for query to the ASA or through the ASA? Please note that the snmp-map command is only for traffic through the box. If you want to disable snmp query to the box, then you need to disable the snmp-server by 'no snmp-server enable'.
08-26-2010 09:13 AM
Hi Yuri,
Hope that helps.
-Mike
08-26-2010 09:23 AM
08-26-2010 12:28 PM
THanks a lot , as I suspected I got it wrong. I was trying to block snmp v3 queries TO the ASA itself .
08-26-2010 12:28 PM
