Iphone connection to Enterprise wireless
Aug 26th, 2010
We currently have an Enterprise wireless network that uses WPA-TKIP and MS-PEAP for authentication.
We are now investigating how to allow iPhone users to connect securely to the network.  I would be interested to hear how other organizations are achieving this currently.
Ideally, we are looking for a method that does not require any user interaction,  i.e. requires a user to click on a button or enter a password.
Surendra BG Fri, 09/03/2010 - 09:24
currently PEAP is used.. that means.. username password rite?? there are multiple ways to achieve your requirements..
ANS - Use EAP-FAST.. one click if the back end is configured correctly..
>> enter a password.
WPA-PSK will do this.. the users will just enter the password.
George Stefanick Fri, 09/03/2010 - 16:40
We have iPhones and iPads on our network. You can treat these like any other device. They will do PEAP just a normal client. You may alreasy know this but Apple has a free deployment tool which allows you to config packages. Its called the iPhone config util... But its for the iPad as well.
hey if you find this helpful please rate the post !
