Variations of DNIS sent to LEC
Answered Question
Aug 26th, 2010
Has anyone ever run into issues in sending the LEC:
1. Local calls with a '1' prefix to the LEC (e.g., if your local area code is 212, and you send the LEC 1-212-555-1212).  Although I imagine this will work in most areas, I seem to remember that being a problem in some instances where the LEC will reject the call.
2. Sending the LEC 10-digits for Local Calls where you are in a 7-digit Local Calling area.  Again, I imagine this will work in most areas, but I'm wondering if someone has seen a LEC choke on this.
Thanks for your comments.
Correct Answer by Paolo Bevilacqua about 6 years 4 months ago
Correct, in both cases the behavoir will depend on telco settings. I have installations in the same city where one site behave one way, and the other the opposite.
Overall Rating: 5 (1 ratings)
Correct Answer
Paolo Bevilacqua Thu, 08/26/2010 - 08:20
Paolo Bevilacqua Thu, 08/26/2010 - 11:06
Altough I have to say case 2 is less likely, as with type/plan ISDN/national, call must be accepted as 10 digits.
Thank you for the nice rating, and good luck!
Aaron Dhiman Thu, 08/26/2010 - 15:30
Paolo, are you saying that you think in an area that uses 7-digit dialing for Local Calls, 10-digit local calls should always work if you set the Number Type to National?  Say area code is 280, and they use 7-digit dialing for Local Calls there  You send:
  • DNIS = 280-NXX-XXXX with Number Type = National.
Then, they would always route that correctly?
Aaron
Paolo Bevilacqua Thu, 08/26/2010 - 15:49
Yes, they should.
Consider that calling numbers always come in as national 10 digits, and can be called back verbatim.
